Omnirig is not correctly installed
F6FLU
Post by F6FLU »
Hello, I'm testing (again) Log4OM and I always have this error
Omnirog is correctly installated into the program Files (x86) Directory and into the subdirectoey "Afreet"
Omnirig works fine with my HDSFR program and with my CWSkimmer Program
I Think I had forgot somethings :-)
I running Windows 10 but the Log4OM Program is intallated into C:\Ham Directory not into Program Files
Can You help me about that ?
Thanks and 73
Dan
Dan - F6FLU
https://F6FLU.org
Re: Omnirig is not correctly installed
Uninstall Omnirig
Download the latest version of Omnirig - IMPORTANT
Install Omnirig with 'Administrator privileges'
F6FLU
Post by F6FLU »
Hi Terry
Many Thanks, that works fine now
I continue to test and I'm reading the good Manual in French :-)
Thanks again
Dan
Dan - F6FLU
https://F6FLU.org
9y4C
Post by 9y4C »
I am having this same issue, tried uninstalling and re-installing but the problem persists, any help will be appreciated
9y4C
Post by 9y4C »
OK, I was able to get Omnirig to install Properly, First i un installed it from my PC then i removed all traces of it from the registry, i then re installed it and now i am able to select it in Log4Om :mrgreen:
