What are your regular expressions ?
PE5TT
Post by PE5TT »
I know that regular expressions are a very powerful filter and selection language, However i am not a powerful regular expressions wizard.
But i made an effort to make one for SES (Special event stations) , its far form perfect and i would like to invite anyone to help and fine-tune it.
((SES)|(ses)|(SPECIAL)|(special))|(([A-Z]{2,4})([0-9]{2,4})([A-Z][\s]|[A-Z]{3,6})|([A-Z]{1,4})([0-9]{1,4})[A-Z]{4,6})
Most special event stations are captured, however due to the frequent use of locator coordinates (XX00XX) SES stations using this call-sign format are excluded as this would make a lot of false triggers.
____________
And while i am at it, i made a small adjustment to the IOTA expression to prevent false positives for call-sign starting with a continent (EU,NA and so)
(AF|EU|AS|OC|NA|SA|AN|af|eu|as|oc|na|sa|an])((-|\s)?)([0-9]{2,4})|((iota)|(IOTA))
Now at least 2 numbers are required before the IOTA flag is triggered , so EU1RUS will no longer trigger the IOTA flag, but EU01 will.
Re: What are your regular expressions ?
Thanks for the input we will update the IOTA Regex and look at the special event Regex
PE5TT
Post by PE5TT »
I wish i was a regular expression guru, then i could probably half the length of the definition below, but i am not.
Some Special Event Stations where missed by the previous version. So now an updated one. Seems to be working quiet well missing only few and also few false positive's.
((SES)|(ses)|(SPECIAL)|(special))|([A-Z]{3,6}[0-9]{1,6}[A-Z]{1,6}\b)|([A-Z]{1,6}[0-9]{3,6}[A-Z]{1,6}\b)|([A-Z]{1,6}[0-9][0-9][A-Z]{3,6}\b)|([A-Z]{1,6}[0-9]{1,6}[A-Z]{4,6}\b)
Wonder if there are any (speed) drawbacks in using such long expressions ?
No performance issues.
each time you write a character on the callsign field a check on 300 regular expressions is made to find the country...
PE5TT
Post by PE5TT »
That's nice to hear. Got another question. it seems like only the "DX CALLSIGN" and the "NOTES" fields are routed trough the regular expression engine.
I am unable for example to highlight certain frequency or band or spotter callsign or anything else. As i am also active on VHF i am trying to get these spots highlighted, since they scarce en could be easily overlooked.
A workaround is a simple Propagation filter tough, witch catches spots with propagation information. As they are mainly VHF / UHF spots
This line will highlights any spots with <TR> Tropo, <ES> Sporadic-E, <MS> Meteor Scatter, <AU> Aurora
((<tr>)|(<TR>)|(<es>)|(<ES>)|(<ms>)|(<MS>)|(<au>)|(<AU>))
One could also add <SAT> and or <EME> , that however is not in my field of interest
