Filter awards by mode
Moderator: OE6CLD
WD9HBC
Post by WD9HBC » 16 Jan 2017, 16:00
I've looked around and didn't see a reference, so I'll ask and if there's someone who knows of a past thread, I'll be happy to review.
I'd like to know if there's a way to filter awards by specific mode. For instance, WAS has a digital filter, but there are endorsements for each specific mode (JT65, PSK31, RTTY, etc) and was wondering if there was a way to track progress towards these endorsements?
Or, do I need to set up my own award to get this information?
Thanks & 73,
Jim, WD9HBC
KW0RH
Re: Filter awards by mode
Post by KW0RH » 29 Mar 2017, 22:59
I have the same question. Is there a way to break out individual digital mode awards?
WD9HBC wrote:
16 Jan 2017, 16:00
Thanks & 73,
Jim, WD9HBC
K7PT
Post by K7PT » 29 Mar 2017, 23:26
Currently Log4OM only tracks AWARDS, not endorsements.
Post by G4POP » 30 Mar 2017, 07:45
The only way you could do that at this time is to:
Use the QSO Archive manager to select just QSO's for the mode of interest i.e. PSK by using the 'Search Parameters' facility
Export those QSO's to an ADIF file
Create a new database (File/New Database)
Import the ADIF file to the new (Empty) database
Use Statistics and awards for the analysis of those QSO's
Revert to original database for normal operations
Its a rather long and ponderous way of doing it but it would provide what you require and the only method currently available
Post by IW3HMH » 30 Mar 2017, 10:09
Correct Terry.
i'm checking if it's easy and fast to add another filter.
Probably yes
CT1BXX
Post by CT1BXX » 30 Mar 2017, 10:24
Hi Daniele,
It was also my intention ask for this, but as you are working on V2 I have not asked, but now I say Excellent if possible, it would be great. :D
73 Manuel Fernando CT1BXX
Post by IW3HMH » 01 Apr 2017, 12:19
added for WAS. Obviously other filters should not be in contrast... so if you ask for DIGITAL award and you filter for SSB no results will be displayed)
Added also a MODE category filter for locator statistics
Will be available soon after beta testing, started today
CT1BXX
Post by CT1BXX » 25 Mar 2018, 22:32
IW3HMH wrote:
30 Mar 2017, 10:09
Correct Terry.
Probably yes
Hi Daniele,
If you permit...
It would be great within User_Awards select the mode we want to track.
I would like to have possibility to create a view for 60Meters for FT8 only.
If we can select a mode we want, we can create several views...
