Terry have you any idea why or has anyone else ever mentioned, when using "Lookup" having QRZ.Com selected as my external source, a "Script Error" highlighting the URL
https://fw.adsafeprotected.com/rjss/www ... /dcmads.js
pops up and the Log4OM stops responding?
Regards
Gerry
Script Error
Re: Script Error
What is your default browser Gerry?ei9ju wrote:Terry have you any idea why or has anyone else ever mentioned, when using "Lookup" having QRZ.Com selected as my external source, a "Script Error" highlighting the URL
Regards
Gerry
Re: Script Error
Hi Gerry,
I had endless issues with Chrome, not least its constant background activity, so eventually I removed it from my computer as did several of my friends for the same reasons.
Unfortunately this means I cant test this issue for you because I wont re-install Chrome under any circumstances, however could you try setting your default browsed to either Explorer or Edge and see if the problem persists please?
Re: Script Error
No problem Terry, I'll switch to Explorer as my default browser and let you know how I get on.
