QSL Label Design Default setting Avery 8160
I accidently hit the A4 button on the bottom of the label design box, Now I don't know the correct margines. IE: Vertical Horizontal in the corrective factor and the printer top margine and so on. Can someone tell me what they are. I'm using AVERY 8160 labels. Thanks.
Mike-W2MJP
Mike-W2MJP
Re: QSL Label Design Default setting Avery 8160
So when I print it seems only the right column is off ( 3rd row). It prints on the break line of the sticker to the left side of it. It is not centered. I spent 3 hours trying to adjust. I tried using the label design but the margine is at 0 already. I also tried making the font smaller but that dont work either. 73.
Mike-W2MJP
Mike-W2MJP
Just select the 8160 template again from the drop down list, it won't have been overwritten unless you saved the A4 size to the 8160 template
I tried that, but I hit save after I thought I may have had the configuration. How can I put it back to default? Or can you screen shot the original 8160 label design box? Thanks.
Mike-W2MJP
Mike-W2MJP
Unzip the attached template to your C:\Users\YOUR USER NAME\AppData\Roaming\LogOM\labels folder and let it overwrite the one already there
Ok thanks Terry.
I will try this when I get home from work. 73. Enjoy your sunday.
Mike-W2MJP
Mike-W2MJP
It will work I have sent you the original template!
