Mass Award Entry
Moderator: OE6CLD
AE4RM
Mass Award Entry
Post by AE4RM » 22 May 2017, 19:28
I just got back from activating a WFF park. I wanted to tag the log for each one with the park ID listed in the awards tab. For each individual log entry, I had to pick the same park (KFF-1829). Is there a way to make Log4OM keep the park name there, like it does with the date, time or frequency?
Thanks,
Roger
AE4RM
Re: Mass Award Entry
Post by G4POP » 24 May 2017, 13:00
No Roger,
Unlike SOTA and IOTA the ADIF specification does not at this time have a field for the activators location reference
The best thing to do is use the bulk editor to add the activator reference to the comments field then perhaps eventually if the ADIF field becomes available those references can be moved across - Like 'My WWFF Ref KFF-1829'
VK5PL
Post by VK5PL » 17 Aug 2017, 05:21
Terry, Logsearch, (the WWFF award site) does have a place for the Activators reference.
Roger, the Award reference under the Clubs and Awards tab is for entering the reference of the other person, not yours, so there is no need to have a lock on that field.
You put your own park reference in Station Info under My Sig (WWFF) and My Sig Info (WWFF-xxxx)(whatever your ref no is)
The other contacts park info goes under Extended info & QSL in Sig (WWFF) and Sig Info (WWFF-xxxx) (whatever his reference is)
Then when the log is uploaded to Logsearch you get credit for Activation and Park to Park Awards.
David
VK5PL
Post by G4POP » 17 Aug 2017, 07:56
VK5PL wrote:
17 Aug 2017, 05:21
As I said its the ADIF specification that does not have a My WWFF field, when it does we will include it
VK5PL
Post by VK5PL » 18 Aug 2017, 13:30
Yes there is not a specific place in the ADIF for WWFF, but we use Sig/Sig Info and MySig/My Sig info at present to get around that.
David
VK5PL
