Page 2 of 3
Re: JT Alert integration.
Posted: 21 Feb 2013, 21:04
by VK3AMA
Art,
I would rather not use this forum for JT-Alert support. I posted the announcement here as a courtesy.
It sounds like you don't have the path to the Log4OM SQLite Log file correctly set with the JT-Alert Settings Window.
All your questions have been answered in the Ham-Apps Yahoo group and I will continue the discussion there.
de Laurie, VK3AMA
Posted: 21 Feb 2013, 22:07
by K0AY
When I was using DM780, the JT65 program got it's QRG from DM780. Having switched to L4OM, I have Omnirig selected on both programs, but the QRG window on the JT65 program stays at 0. the CAT function is working on L4OM. What do I need to do to have the JT65 program get the QRG from L4OM? Many thanks for all your help.
Art K0AY
Posted: 21 Feb 2013, 22:29
Start JT65 first so that it has the frequency and mode from Omnirig then when it logs to LOG4OM it will log the frequency used
Posted: 22 Feb 2013, 11:52
Laurie is using the same process of DM780,that will not expect an answer. If he needs a different way i can provide a dedicated listener on a dedicated port that provides an answer in the required format (that i don't know actually).
Posted: 26 Apr 2013, 22:38
by K0AY
IW3HMH wrote:Laurie is using the same process of DM780,that will not expect an answer. If he needs a different way i can provide a dedicated listener on a dedicated port that provides an answer in the required format (that i don't know actually).
That would be very useful to me
Art K0AY
Posted: 18 Aug 2016, 19:05
by VE9ZZ
Hi everyone. I'm new to Log4OM and would like to use it to log QSO's from JTAlert. I'm abandoning HRD and looking for another logging program to use. When I try to log a contact I get an error. Attached is a screen capture of the error. It refers to HRD but I cleaned HRD completely from my PC, I even did a regedit to clean it further. Anyway I hope someone can help me out. I followed all the directions in the manual for locating the log file but still get the error. I'm using 1.25 portable.
Thanks in advance de VE9ZZ
- logging error.png (151.56 KiB) Viewed 9041 times
Posted: 19 Aug 2016, 06:42
I believe that although JT Alert is flagging an error that you will find that Log4OM has actually logged the QSO, have you checked?
Posted: 19 Aug 2016, 10:25
by VE9ZZ
Thanks Terry , yes I checked and it doesn't log the contact.
de VE9ZZ
Posted: 19 Aug 2016, 11:31
VE9ZZ wrote:Thanks Terry , yes I checked and it doesn't log the contact.
de VE9ZZ
Are you certain that the JTAlert configuration is set up correctly for Log4OM?
Perhaps someone that uses JTAlert could advise you
Posted: 19 Aug 2016, 12:37
by VE9ZZ
Been over it more than a dozen times, my head is starting to hurt. I'll log the contacts manually for now and hope someday I'll find the solution.
Thanks 73 de VE9ZZ
