LoTW weirdness
WT0DX
Re: LoTW weirdness
Post by WT0DX »
In the 1.31.00 release.... is this the fix for the LOTW download issue: "Added checks to WAS import in order to try fixing non coherent data for USA, Alaska and Hawaii." ?
Bill WT0DX (formerly WB9KPT)
Re: LoTW weirdness
Yes
EC1DQ
Re: LoTW weirdness
Post by EC1DQ »
Hi all,
I updated to the last release and I still have something with a "DC" station. It appears like state number 51, as "DC // District of Columbia" on the state field and "DISTRICT OF COLUMBIA" on the County field. It appears with the same red box (NOT FOUND) as it did on last version with the other states. Any comment about it?
Thanks!
w0ls
Re: LoTW weirdness
Post by w0ls »
It appears that this version (1.31) fixed all of my state entries. Thanks!!
Harry
W0LS
Re: LoTW weirdness
EC1DQ wrote: 28 Jan 2018, 18:23 Hi all,
Thanks!
That is not a Log4OM or LotW Problem. It´s a problem of the Callsign Owner which write "DC" as a State in qrz.com or other
online services. The same appears for the DXCC U.S. Virgin Islands when those Users write "VI" in the state field.
DC is not a state of the United States and VI also is not one, but those wrong inputs at qrz & co. will force this problem.
An example:
If i go to qrz or hamqth and fill "RP" (for Rhineland Palatinate" in the state field you will have an unknown state more in the
WAS statistics. It´s outside of the United States (as VI for Virgin Islands is too) but it will be shown as "Unknown" in the WAS
Stats ...
Re: LoTW weirdness
Log4OM fixes only states in usa, Alaska and Hawaii that have a valid state in the was.csv reference file. Everything else it's managed as unrecognized and Log4OM doesn't touch data it doesn't perfectly know
Re: LoTW weirdness
So, I am assuming DC (which is a weird one) just needs the state removed and save it?
Re: LoTW weirdness
yes, or replaced with the correct state.
WA2SQQ
Re: LoTW weirdness
Post by WA2SQQ »
So I had many entries that had this problem. I corrected many, manually. I just updated to 1.31.1 Will this fix all the remaining ones automatically, or only new entries looking forward?
Re: LoTW weirdness
WA2SQQ wrote: 02 Feb 2018, 23:11 So I had many entries that had this problem. I corrected many, manually. I just updated to 1.31.1 Will this fix all the remaining ones automatically, or only new entries looking forward?
Which issue are you refering to the change of syntax by LOTW or the recording of incorrect stat information like DC?
