Dear Programmers of Log4OM, I have WindowsXP SP3 and Log4OM v1.31.1.0 and from 1 day about Log4OM starting and loading my log database but crashing and close automatically.
This incorrect behavior (very stranger) is from 1 day only, but I not have changed none configuration.
I testing an downgrade to the v1.31 and v1.30 and v1.29, but the software crashing and close automatically, again with the others previous version.
I not have any other PC for upgrade to the last v1.32 of Log4OM.
Is possible help to me?
Many thanks for your interest to my problem.
Bye for now.
Log4OM v1.31.1.0 + WindowsXP SP3 problem on start
Re: Log4OM v1.31.1.0 + WindowsXP SP3 problem on start
Dear Programmers, I tested Log4OM v1.31.1.0 with return to yesterday date of my PC and VERY STRANGER the software WORKING GOOD.
If I return to the today date of the PC (25/03/2018) Log4OM stopping and crashing again.
If I return to the yesterday date of the PC (24/03/2018) Log4OM working good.
Is possible Help me?
Many thanks.
Many thanks.
Date of the day.
If I set my date of PC to day 24/03/2018 Log4OM v1.31.1.0 working very good.
If I set my date of PC to day 25/03/2018 Log4OM v1.31.1.0 crashing and close automatically on starting phase.
If I set again date of PC to day 24/03/2018 Log4OM working very good again.
This is the problem.
And I test again:
If I set the date of the day to 24/03/2018 and I starting Log4OM: THE SOFTWARE START GOOD AND WORKING GOOD.
When Log4OM is started OK, I change ON THE FLY the day to 25/03/2018: THE SOFTWARE WORKING GOOD AGAIN.
The problem is on starting Log4OM with date of the day setted to 25/03/2018 directly.
This is the stranger problem.
And I test again:
I have asked Lele to respond to you a couple of days ago because I don't have any ideas about this one
The solution is probably contained in the log file...
did you check log file for errors? some details?
Log4OM use internal clocks to take care of syncronization, so changing the system date "could" create issues...
Dear Daniele, I'm desponsable for this inconvenient, but I not have any problem in evidence on my logbook.
If you have interested to solve the problem I send to you my Log via email or other system, for control eventually problem not in my evidence.
Give to me the mode of send my logbook (the attacchement in this forum is not possible for file too long, also zipped about 825 KB).
