Log4OM and Omnirig
Re: Log4OM and GridTracker
HB9BRJ wrote: 24 Apr 2018, 19:10
G4POP wrote: 19 Apr 2018, 20:21Hi Marcus,
We are working with Stephen the author of GridTracker and as a result you will see some new features in GridTracker for the next release, including a worked before warning based on the imported Log4om adif file.
RST sent/rcvd are consistently written into RST rcvd/sent on the Log4OM side.
I have notified Stephen
Some countries are not identified and left blank, e.g. 2I0GFR (Northern Ireland).
Are you sure the call was not recorded as twenty one zero GFR?
HB9BRJ
Re: Log4OM and Omnirig
Post by HB9BRJ »
The missing country issue also happens with "common" countries like Germany. Yesterday I logged several QSOs with German stations. In all but one cases, the country was correctly added.
The cause of the RST mix up error is on the GridTracker side: Checked Log4OMs Communicator activity log which clearly shows that RST sent and RST rcvd are already mixed up in this line:
TCPManagement: Incoming QSO from TCP Connection (ADD) <BAND:3>30m...
In very rare cases however GridTracker provides correct RST reports. Strange.
73, Markus HB9BRJ
G4DWV
Post by G4DWV »
I have tried GridTracker. However, having used and configured JTAlert to my requirements, GridTracker would have to come up with something really special to make me switch.
From what I have seen that "something" is not there yet.
I am open to persuasion in case I may have missed anything.
Guy G4DWV 4X1LT
