Lost logbook
Yes, this is the RTFM place, at your service
m0hwa
Lost logbook
Post by m0hwa » 22 May 2018, 13:11
I lost all my logging, and unknown to me... the upload code for hrdlog.net, has anyone any idea how I can get back my old log,
thanks... Merfyn-M0HWA
Re: general
Post by G4POP » 22 May 2018, 15:51
Hopefully you wont have lost it just search on *.SQLite (Star dot SQLite) and you should find your main database - Then just go to File/Open Database in Log4OM and it should all be OK.
Otherwise there is probably a backup file, assuming you set one in the options menu? which will probably be located at C:\Users\YOUR USER NAME\AppData\Roaming\LogOM\Backup use the one with the latest date and then first create a new database in the Log4OM file menu and then File/Import ADIF (Select the latest one noted above)
