how to communicate Log4OM with MSHV
Re: how to communicate Log4OM with MSHV
I have never heard of it, explain please
No a virtual port is for CAT control not logging
The author of the other software would need to add a provision to log to our software in the same way as JTAlert
Alternatively if JTalert works with this other software then JZTAlert can pass the QSO tò log4om
sp8sn
Post by sp8sn »
Hallo.
The new version of MSHV has the feature of sending log packages via UDP:
New in version 1.82:
Added: In "Radio And Network Configuration", new Group box "UDP Broadcast Settings:" and two options for broadcast QSOs, Logged QSO Broadcast and Logged QSO ADIF Broadcast.
Important: Before update to new version, please backup your previous log from (dir log file mshvlog.edim).
Function "Logged QSO Broadcast" has an exception if you use Logger32: eg. In "Multi Answering Auto Seq Protocol", it is possible to end QSOs with 5 stations simultaneously within the same second. Logger32 will save only first QSO, for this reason, the seconds for each QSO, if they are in same minute, MSHV tags them electronically from 00-59.
UDP Broadcast has been tested with Logger32 for function "Logged QSO Broadcast" and N1MM for function "Logged QSO ADIF Broadcast".
Is it possible to use this feature with LOG4OM. I tried different port settings, but unfortunately it does not work.
73, Robert SP8SN
73, Robert SP8SN
I cannot assist or test this software for compatibility because the download is password protected.
If the author contacts me then perhaps I can do something for you
sp8sn
Post by sp8sn »
Yes please ask Christo for a password. This will be no problem.
I talked to him about this problem.
Robert
73, Robert SP8SN
You can broadcast whatever you want... if nobody listen it's hard to have an answer :D
sp8sn
Post by sp8sn »
IW3HMH wrote: 09 Aug 2018, 14:44 You can broadcast whatever you want... if nobody listen it's hard to have an answer :D
Hallo. Do you suggest that Log4OM does not listen?
This the the best logging program I've used, but MSHV is the best for some digi modes.
I would like to "marry them".
Robert SP8SN
73, Robert SP8SN
I'll check what this software is broadcasting...
Any link to the application webpage?
sp8sn
Post by sp8sn »
73, Robert SP8SN
sp8sn
Post by sp8sn »
IW3HMH wrote: 02 Sep 2018, 10:23 I'll check what this software is broadcasting...
Hallo Daniele.
Did you try to solve the problem. Do you have any way to log in QSO from MSHV to Log4OM?
Robert
73, Robert SP8SN
