Questions about Tuner Reminder
KW0RH
Post by KW0RH » 16 Sep 2018, 19:02
I really like this utility and between my tuner and my amp I get a lot of use out of it. I have a couple of questions and I can't fine the utility even mentioned in the help file.
1. Is it possible to edit the "Device" and "Antenna" contents of the dropdown boxes? I have a couple of now-defunct antennas on the list that I'd like to delete from the listing and can't figure out how to do it.
2. Is there a way to keep the box on top so that it's always visible? If not, is there a hotkey combination to call it up rather than going through the UTILITIES/TUNER REMINDER mouse sequence every time?
Rick K0VC
Re: Questions about Tuner Reminder
Post by G4POP » 02 Oct 2018, 06:37
KW0RH wrote:
16 Sep 2018, 19:02
Click the green check mark to open the editor
