QRZ Upload stopped working
DG7LAN
Post by DG7LAN » 28 Sep 2018, 07:54
Hi Folks,
my QRZ upload stopped working a month ago. I recognized it today though.
My API key is still the same in the config and on the QRZ page.
I don't know if the problem is related to QRZ or log4om (would be more my configuration than the program) but is there a way to debug the QRZ upload?
Kind of a hidden log file or command line option? I have no idea where to start from.
And by the way: I know, I can right click on a single QSO to force upload to QRZ. Is there a way to do it with a selection of QSOs? (Other then exporting to adif and upload manually)
Thanks for your help,
Andy
Re: QRZ Upload stopped working
Post by G4POP » 28 Sep 2018, 08:01
Using you call sign as a user name might have helped us with your issue but as it is I can't check QRZ!
Did you check that your paid for QRZ XML subscription has not expired?
Did you check that your logbook end date in QRZ is still a valid future date?
Did you check the Log4om log file (help/show log) for errors?
DG7LAN
Post by DG7LAN » 28 Sep 2018, 08:30
Hey Terry,
I tried to use my call as the username but I could not get the activation link. Thats why I registered again to place my (dumb) question.
Really sorry for wasting your time. The subscription did indeed time out. :I
Thanks for pointing me to the debug log. Was it always there under "help"? Fantastic and verbose enough to see whats going on under the hood.
Have a nice day and thanks again, Andy / DG7LAN
Post by G4POP » 28 Sep 2018, 09:01
Do you want me to edit your user name to your call sign?
DG7LAN
Post by DG7LAN » 28 Sep 2018, 10:57
That would be nice.
Can you delete the old account? Its registered with dg7lan at gmx.com (should be)
73 Andy
Post by G4POP » 28 Sep 2018, 11:02
Done
Post by DF5WW » 28 Sep 2018, 11:07
Impossible things would be done in realtime ... only wonders need a bit longer ... :D :D ;)
