First of all, im very pleased with LOG4OM it's a nice and easy to use log program.
I want to thank you all for making this fantastic program.
I have although a question...i'm using LOG4OM version 1.34.0.0 and i'm trying to download LOTW and eQSL logs into LOG4OM.
When i do this some qso's give's an error message: 'QSO Not Found...'. This is very strange because they are confirmed qso's.
Sreenshot of the messages:
The settings in LOG4OM are:
I'm also using the latest version of TQSL, all the passwords and username's do not contain any 'special characters'.
Is this a known issue, and is there an solution fo this problem?
I hope you can help me.
73, PD8GZ
Gerrit
no QSO's found LOTW and eQSL
Re: no QSO's found LOTW and eQSL
Have you checked the two qso's in your log to make certain that the call sign, date, time, frequency, band and mode are an EXACT match?
Thank you for your reply,
The QSO's seems to be oké....except time and frequency.
Here are the screenshots: Thank you.
Gerrit
Gerrit
Clearly if the time and frequency don't match then the download from QRZ will treat the qso's as different qso's and the result is QSO not found!
Terry,
Oke, thank you for your fast replies.
So is it possible to change these or is not done?
Gerrit
Gerrit
Of course! Change the information in Log4om to match and then download again from LOTW
These minor mismatches sometimes occur due to users setting up WSJT in a different manner or variances in old style loggers
Terry,
These QSO are not yet logged in LOG4OM.
I want to download them from LOTW into LOG4OM, the other QSO's are downloadeble except these.
I assume that changes should be made in LOTW and then correctly downloadable into LOG4OM.
Thank you for your help.
73, Gerrit
73, Gerrit
You misunderstand the function that you are using in Log4om, it's for updating Qso's that already exist in Log4om from an LOTW record.
It is not an import function, you need to download an ADIF file from whatever external source you use and then import it into Log4om.
Refer to our user guides and YouTube tutorials for a complete understanding of how Log4om works
