MySQL not in sync, different amount of QSOs
hb9cat
Post by hb9cat » 04 Dec 2018, 08:57
I'm running a MySQL server on a PC
Log4OM running on the same PC shows 9116 QSOs, bottom left
Log4OM running on a remote PC connected to the very same MySQL DB shows 9108 qsos
I did click on refresh on both sides
How can there be a mismatch ion the # of qsos if it's the same DB ?
Marco HB9CAT
Re: MySQL not in sync, different amount of QSOs
Post by G4POP » 04 Dec 2018, 11:33
Have you possibly got a filter applied in the 'Search Parameters'
hb9cat
Post by hb9cat » 04 Dec 2018, 18:58
Thanks for your reply,
no I have no filter applied; and actually even setting a filter in "search parameters" does not change the total amount of qsos reported bottom left.
Marco HB9CAT
hb9cat
Post by hb9cat » 07 Dec 2018, 00:00
QSOs are back in sync, I didn't do anything other than restarting the software a few times on both sides; so I have to guess it was a bad synchronisation with the MySQL server
Marco
Post by IW3HMH » 08 Dec 2018, 13:57
Do you have mysql files synced on something like google drive or dropbox?
