N1MM
N1MM
Post by G4POP » 17 Dec 2018, 20:19
I need a couple of users that use N1MM to step forward and do some beta testing please
Re: N1MM
Post by KD0ZV » 17 Dec 2018, 20:39
Be happy to help. I use N1MM about once a month for CW contests.
Re: N1MM
Post by G4POP » 17 Dec 2018, 20:44
kd0zv wrote:
17 Dec 2018, 20:39
Please email me at g4pop (at) arrl.net and I will ask you to try a Beta of version 1.36 which enables N1MM to log direct to Log4OM in real time and as the QSO is added to Log4OM the missing data like country, grid square etc are updated
HB9ETR
Re: N1MM
Post by HB9ETR » 18 May 2019, 07:51
Hi Terry
The N1MM integration is great. Makes life easier than importing.
One thing I noticed, which I hope you may have an answer/solution to....
The QSO END time doesn't populate for me.....it never did when importing either.
Is this "as is" or have I missed something?
Rob
HB9ETR / G0IFL
Re: N1MM
Post by G4POP » 18 May 2019, 08:36
HB9ETR wrote:
18 May 2019, 07:51
I just tested this and as you can see from the incoming data from N1MM shown below, N1MM is not sending us an end time so we cannot log it.
019-05-18 08:30:32.9341 INFO: TCPEventManager: Add QSO From external request via N1MM: ADIF INFORMATIONS:<ANT_AZ:1>0 <CALL:5>G0HZZ <COMMENT:60>Must be H, HQ, C, CM, N or NC (CLUB HQ, CLUB MEMBER or NO CL <CONTEST_ID:8>RSGBCLUB <FREQ:5>3.765 <FREQ_RX:5>3.765 <MODE:3>LSB <OPERATOR:5>G4POP <STATION_CALLSIGN:5>G4POP <PROGRAMID:6>Log4OM <PROGRAMVERSION:8>1.37.0.0 <QSO_DATE:8>20190518 <RST_RCVD:2>59 <RST_SENT:2>59 <RX_PWR:1>0 <SRX:3>989 <SRX_STRING:3>989 <STX:1>1 <STX_STRING:1>1 <TIME_ON:6>083032 <TX_PWR:1>0 <SFI:1>0 <EOR>
