I've seen that when you make a post on the cluster (when you operate 60m cw) the result mode is phone and not cw.
At the same time is not possible to search for mode cw in 60m. Is it a limit of the system? do i make some mistake?
60m cw cluster spots error
Re: 60m cw cluster spots error
You need to edit the bandplan to match your frequency allocation for 60m
