Is there anyway of reading the power levels rather than having it fixed in the setup menu.
I use a Icom IC-7100 (50watts) and a Icom IC-7300 (100watts)
Cheers
Bill G4CFP
Power Levels
Power Levels
Bill G4CFP
Re: Power Levels
I don't believe that either Omnirig or Hamlib provide commands to read the TX power level but I will check!
Re: Power Levels
I have now checked the Omnirig commands and find that Omnirig do not provide a way of reading the TX power level set on the radio or any way of setting the power levels from Omnirig.
I specifically checked the Icom radios IC7000, 7100, 7300, 7600, 7700 and 7800
I suspect Hamlib may provide this feature because FLRig has a PWR level control and I beleive that uses Hamlib
