Fldigi 4.018 Log4OM connection issue
nigelspear
Post by nigelspear » 24 Jan 2019, 10:47
This is one of those annoying software issues - in that something that was working is now not! The question is "OK so what changed?" As far as I know I have changed nothing other have been playing with some of the audio settings in Fldigi - which I cant see could affect its ability to talk to LOG4OM.
My setup is:
Fldigi setup to use xmlrpc
LOG4OM
Fldig, Log4OM are running as administrator
The windows firewall is disabled
There is no additional security software on this machine (other than Windows Defender)
Although it worked before - only changes to the frequency from my rig got reflected correctly. Changing the frequency on Flidigi never got reflected
Re: Fldigi 4.018 Log4OM connection issue
Post by DF5WW » 24 Jan 2019, 11:09
Hello OM,
did you have hit the "Initialize"-Button in the XMLRPC setting at the first start of
Fldigi as described in the Fldigi setup in the manual ? Did you start Fldigi first before
you start Log4OM like described in the manual too ?
Last but not least, are all the lights are green in the Log4OM communicator when
Fldigi and Log4OM are running ?
If not all green you can check them manually .....
By the way, frequency changes in Fldigi not resulting in changes in Log4OM and the Transceiver.
nigelspear
Post by nigelspear » 24 Jan 2019, 12:01
Hi
Yes I have hit the initialise button in the XMLRPC setting.
The connection buttons to and from FLDIGI are both red
If I manual push the start buttons - they both go green for a few seconds but then return to red. If I switch to the log tab, I see it trying to connect but keep getting the "unable to connect to remote server" message (as in the log screen capture above"
Im starting FLDIGI before LOG4OM
Thanks for the suggestions!
Post by G4POP » 24 Jan 2019, 14:20
Did you recently update Fldigi?
nigelspear
Post by nigelspear » 24 Jan 2019, 14:45
Hi
No this is the version I have been running for a month or so
Post by G4POP » 24 Jan 2019, 15:07
For some reason the FLDigi server is not available, according to the logfile you posted here.
So check that there is no other CAT control enabled in FLdigi like rigcat, Hamlib or flrig
Try a fresh install of FLdigi
Check your firewall or virus software is not blocking the connection
If none of the above fail to resolve the issue ask on the FLDigi forum about reasons for the server not to function
incidentally I have FLDigi Version 4.0.18 running perfectly with Log4OM version 1.36
Post by G4POP » 24 Jan 2019, 15:22
also are you sure that you have changed nothing here?
The lock box should be checked I unchecked it for clarity of image
nigelspear
Post by nigelspear » 25 Jan 2019, 09:44
Thanks for all the suggestions
Fldigi configuration looks fine
All of the other tabs in rig control are not selected (FLrig,RigCat,Hamlib and Hardware PTT)
Firewall - there is no firewall running on the small windows box im using for LOG4OM and Fldigi
I have tried reinstalling Fldigi.
However although I de-installed using programs and features, this must leave something behind as my settings were retained when I re installed (ie operator info, macros etc)
Are there additional steps to completely eradicate Fldigi when you de-install?
Post by G4POP » 25 Jan 2019, 09:50
No it's NOT the same
You have changed the XML port number, change it back to match the screen shot I posted 7362
Don't forget to save the configuration from the Fldigi file menu as well as the window above
nigelspear
Post by nigelspear » 25 Jan 2019, 11:09
SOLVED!
You are a star Terry
Its always the way, you cant see something for the sake of looking!
No idea how that got changed as I have never been into that screen before, and I would have assumed locked means it cant be change.
Nevertheless, that immediately fixed the problem
Thanks for all the community help
