Hello FM,
The lookup function to qrz or other doesn't work anymore. Yesterday evening it was working, not today.
No changes made and the login and poasswords are correct ?
Whats wrong.
73 - Rudi
QRZ or other lookup
Re: QRZ or other lookup
First question - What version number of Log4OM are you using - see Help/About if you are not sure
Seems QRZ may have changed something - Checking
HamQTH works fine
HamQTH works fine
Yes Hamqth working, also QRZcq not working here.
Qrz working again, the problem was not with Log4om.
QRZ.COM XML Server was down, now up & running.
http://forums.qrz.com/index.php?threads ... st-5022820
73 de David G4NVB
A small step by step for all users of Log4OM having problems like this:
1 -- Try to login manual to the website which contains the lookup service ...
2 -- For qrz.com users .... If you have an XML subscription check out for the enddate or you got only a smaller package of information.
(like no Gridsquare or something else)
3 -- If you can login manually to the other services contact the service owner and tell him the problem with the Log4OM lookup.
Last but not least -- Don´t forget to inform this community when you receive an answere of the service owner and the problem is resolved ...
73´s .. Juergen ... ALT-512 SDR (10W) , 50 m random wire at CG-3000 autotuner, Ailunce HS2 (20W and 5W VHF/UHF) to LPDA´s and different vertical´s ...
