Configuration missing
IK7HTB
Post by IK7HTB »
Hi everyone,
a friend of mine has an issue with log4om configuration. He sometimes miss the configuration and it's necessary to reload all the information again.
I found this error in the log :
2019-08-04 09:10:19.5138 INFO: FileManagement: CONFIG begin load
2019-08-04 09:10:19.5294 ERROR: * FileManagement: Error in FileManagement in DeserializeConfig function for log C:\Users\Utente\AppData\Roaming\LogOM\config.xml *** [Function: DeserializeConfig] System.Runtime.Serialization.SerializationException: Il flusso binario '0' non contiene un BinaryHeader valido. Ciò può essere dovuto a un flusso non valido o a una modifica della versione dell'oggetto tra la serializzazione e la deserializzazione.
in System.Runtime.Serialization.Formatters.Binary.__BinaryParser.Run()
in System.Runtime.Serialization.Formatters.Binary.ObjectReader.Deserialize(HeaderHandler handler, __BinaryParser serParser, Boolean fCheck, Boolean isCrossAppDomain, IMethodCallMessage methodCallMessage)
in System.Runtime.Serialization.Formatters.Binary.BinaryFormatter.Deserialize(Stream serializationStream, HeaderHandler handler, Boolean fCheck, Boolean isCrossAppDomain, IMethodCallMessage methodCallMessage)
in LogOM.BL.FileManagement.DeserializeConfig(String fileName)
2019-08-04 09:10:19.5634 ERROR: * FileManagement: CONFIG load error *** [Function: LoadConfig] System.Runtime.Serialization.SerializationException: Il flusso binario '0' non contiene un BinaryHeader valido. Ciò può essere dovuto a un flusso non valido o a una modifica della versione dell'oggetto tra la serializzazione e la deserializzazione.
in LogOM.BL.FileManagement.LoadConfig()
Can anyone help me in fixing?
Thank's in advance and 73
David, IK7HTB
Re: Configuration missing
Seems an issue on config save, that cannot be loaded back next time you open. Please after closing Log4OM check for errors and send me the relevant part of the issue. Log you sent is getting the problems caused by previous erroneous save
