1.39 question
W4EBB
1.39 question
Post by W4EBB »
I use JTAlert with wsjt-x. Am I correct that if I install Log4om I have to "turn on" the new UDP support in Log4om and then turn it off in JtAlert.
If I don't turn on the new UDP support in Log4om then all should be okay. Right?
Charlie
Re: 1.39 question
If you leave all as is in your settings logging via JTalert to Log4OM will be the same as before.
If you enable new UDP in Log4OM and not turning off in JTalert there will be double entries
in your Log. For direct WSJT-x to L4O enable new support in the logger and disable in JTalert.
W4EBB
Re: 1.39 question
Post by W4EBB »
Thanks!
My follow-up question: is there an advantage one way or the other?
Charlie
Re: 1.39 question
Hi Charlie,
don´t think so. On my end i will log via JTalert as in the past but some guys need direct logging
from WSJT-X (JTDX) to Log4OM without the need of JTalert.
N6VH
Re: 1.39 question
Post by N6VH »
There could be one disadvantage to logging with WSJT-X instead of JTAlertX. If you do this, JTAlert might not work for giving you alerts, and Scan Log might not work.
Re: 1.39 question
N6VH wrote: 29 Aug 2019, 20:29 There could be one disadvantage to logging with WSJT-X instead of JTAlertX. If you do this, JTAlert might not work for giving you alerts, and Scan Log might not work.
And that may not be any problem for some OM. They may not want to use JTAlert or may not even be aware of its availability.
At the least this gives more options and functionality.
N6VH
Re: 1.39 question
Post by N6VH »
KI5IO wrote: 30 Aug 2019, 11:18
Yes, I understand that. However, the OP asked - "My follow-up question: is there an advantage one way or the other?"
I was merely answering his question.
Jim N6VH
NN7D
Re: 1.39 question
Post by NN7D »
You can log directly from WSJTx to Log4OM, and still run JTAlert for its alert features. Just turn off Log4Om logging in JTAlert.
I believe based on my experience that direct logging is more reliable.
Doug
W7DRM
N6VH
Re: 1.39 question
Post by N6VH »
W7DRM wrote: 01 Sep 2019, 05:51 You can log directly from WSJTx to Log4OM, and still run JTAlert for its alert features. Just turn off Log4Om logging in JTAlert.
Doug
W7DRM
If you turn off Log4OM logging in JTAlert, then Scan Log and Rebuild won't work, and therefore, alerts won't work correctly either. It is certainly possible that some might not need or want those features, but it is something to be aware of.
Based on my experience, JTAlert logging is very reliable. I did have to increase the timing for the Check QSO Log Record setting, but then logging works fine.
Jim N6VH
