Question About Omnirig and IC-7300.ini
OZ2PKM
Post by OZ2PKM » 12 Oct 2019, 10:09
Hi I have a problem, with Log4om and IC 7300,
when I press spots, the radio switches to filter 2,
I suppose it is in the Omnirig IC-7300.ini file I need to change a command,
is anyone know which one. and how to make it stay in filter 1 in USB mode.
/Jens
W7DRM
Re: Question About Omnirig and IC-7300.ini
Post by W7DRM » 12 Oct 2019, 20:22
Hi Jens,
Its been a while since I explored this, but off the top of my head - the Filter 2 deal is an ICOM default when a Freq/mode QSY is sent by CAT, at least for my IC-7600. It may also be an OmniRig default.
The simplest solution is to program your radio Filter 2 to be the filter you want as standard. That is what I have done. This might require you to swap say Filter 1 settings with Filter 2 settings.
I hope that helps,
Doug
W7DRM
OZ2PKM
Post by OZ2PKM » 12 Oct 2019, 20:34
Ok thanks :)
/Jens - OZ2PKM
