Lost Cat Control
g7fkj
Lost Cat Control
Post by g7fkj »
Yaesu 450 D
Windows 10
I had log4OM working fine with my radio and was able to cahange frequency and band using the mouse and computer. The frequency was also shown on the pc and contacts were all logged automatically.
Some time ago it all stopped working, I assume due to a windows update changing the driver.
I have tried installing what I believed to be the correct driver but with no success.
Any advice on the correct driver (and where to get it) and how to install it on a micro pc with no cd or floppy drive would be appreciated.
Yaesu 450D
Windows 10
Sandpiper MV10 Aerial
Regards
Colin
Re: Lost Cat Control
As far as I know there is not a special driver for the FT450, you just plug in the USB interface cable and Windows allocates the driver and com port.
In Device manager look at LPT & Com ports and watch what happens as you plug and unplug the interface cable, you will see a new port appear as you plug the cable in, this is the com port you should use in Omnirig for your radio interface.
Now check what baud rate the radio has set in its menu for the CAT interface and use the same baud rate in Omnirig
Once you have selected the radio, com port and baud rate in Omnirig click OK and you should have a working interface
g7fkj
Post by g7fkj »
Thanks Terry
Double checked everything but I cannot see what I am doing wrong.
I have attached a screenshot to see if you can see where I have gone wrong.sorry the photo was too large to send
Yaesu 450D
Windows 10
Regards
Colin
No screen shot
Email me to arrange either a Team viewer or Skype session
g7fkj
Post by g7fkj »
Will do
Screenshot.pdf
Screenshot
(166.06 KiB) Downloaded 706 times
Yaesu 450D
Windows 10
Regards
Colin
Nothing received so I guess you fixed it?
g7fkj
Post by g7fkj »
Good Afternoon Terry
You answered a post I placed on the forum regarding the lost cat control between my Yaesu 450D, Pc and log40M. I suspected it is a driver issue.
You suggested using Team Viewer ansd Skype to help sort the issueieI sooleaase elt me know when you are freee and how to go about skyping you?
Seasons Greetings to you and yours
Regards
Colin
Yaesu 450D
Windows 10
Regards
Colin
Email me at g4pop (at) arrl.net
