RST in JS8 mode
HB9BRJ
RST in JS8 mode
Post by HB9BRJ » 27 Nov 2019, 19:50
JS8Call by KN4CRD has found my interest again.
I added JS8;JS8;MFSK;JS8 to ModeList_user.csv.
Since ADIF file polling is working just fine with WSJT-X, I created a new Log4OM CONFIG pointing at my JS8 ADIF log file. QSO data is correctly imported into Log4OM, including the FT8 style SNR figures.
When I edit such a QSO, RST shows as 599 dropdown lists. How can I tell Log4OM to use JTxx mode RST also in JS8?
73, Markus HB9BRJ
Re: RST in JS8 mode
Post by G4POP » 28 Nov 2019, 11:32
HB9BRJ wrote:
27 Nov 2019, 19:50
73, Markus HB9BRJ
What version of Log4OM are you using - See Help/About
HB9BRJ
Re: RST in JS8 mode
Post by HB9BRJ » 28 Nov 2019, 18:28
G4POP wrote:
28 Nov 2019, 11:32
Version 1.40.0.0
Re: RST in JS8 mode
Post by G4POP » 28 Nov 2019, 18:43
Ok that's the same version I have and it's the latest version.
I have not found an issue but let's make sure we are both on the same page, I am assuming you are doing the following!
1. A QSO is automatically imported from the adif file
2. The imported QSO shows the correct RST sent and received values in the Log4om recent QSO window (F8)
3. You open the QSO edit window by double clicking on the QSO in the recent QSO window
At this point you say the RST value gets changed?
HB9BRJ
Re: RST in JS8 mode
Post by HB9BRJ » 28 Nov 2019, 19:43
G4POP wrote:
28 Nov 2019, 18:43
- imported QSO shows RST -01 / +01
- edit QSO: RST shows as 599 / 599, the default CW value
- Cancel button: original RST -01 / +01 still ok in the log
- Save & Exit button: RST overwritten with 599 / 599.
