Page 5 of 7
Re: JTalert and Log4OM version 2
Posted: 26 Jan 2020, 10:20
By the way i have the same issue...
And i'm quite sure (you can trust me) that error message is not being raised by Log4OM 2
Unfortunately i don't have enough info about reasons this error is triggered on JTAlert, but it happens also when Log4OM is not running so it's hard to get it.
I have it both on WSJT and JTDX
Posted: 26 Jan 2020, 10:35
by sq9jxb
DF5WW wrote: ↑26 Jan 2020, 10:17
If you have not used MySql in Log4OM you have to do nothing. When installing normally all is set
to use SQlite. You have only to change in JTalert but if the setup window will not open there it
could be another problem. But it´s JTalert problem and not Log4OM. If this is reported by other
JTalert users on Lauries site i think he will be fix this. But you can try a fresh installation of JTa
so it could be possible that you have only a corrupt installation.
Hello Juergen
Yesterday I did several installation attempts and the effect was always the same.
It is reported to VK3AMA, because it's not only I who has such a problem.
If there was a problem then JT-Alert 2.15.7 Beta 0001 would not work and it works without a problem.
The problem is in JT-Alert - VK3AMA does not yet know what and recommends using the working version.
Regards
Posted: 26 Jan 2020, 10:39
by sq9jxb
IW3HMH wrote: ↑26 Jan 2020, 10:20
Hello Danielle
As I described earlier, this is a JT-Alert problem, not Log4OM.
Version 2.15.7 Beta 0001 works for me.
We need to be patient until VK3AMA solves the problem
Regards
Posted: 28 Jan 2020, 15:51
by WA2SQQ
I have been following the JTALERT migration to LOG4OM since V2 was released. This was the only “issue” that introduced hesitation to installing V2. All appears to be working now. I’m wondering if there is a preferred upgrade path.
1. Should JTALERT be updated to the latest version before updating to V2?
2. When I install V2, will it automatically read any V1 config settings that were associated with V1 and JTALERT?
3. Are there any compelling reasons to run both LOG4OM V1 & V2, or does V2 seem stable enough to drop V1?
Posted: 28 Jan 2020, 16:00
WA2SQQ wrote: ↑28 Jan 2020, 15:51
Either way it does not matter
No the structure is completely different, please refer to our user guide
Depends how trusting you are, I have been exclusively using V2 for several months but there is a simple interface between V1 and V2 that will keep V1 in synchronisation with V2 if your concerned - This again is fully documented in our user guide
Posted: 29 Jan 2020, 18:46
by WA2SQQ
Thanks Terry - I've been reading the manual and watching the videos. It is time well spent. Well written and easy to understand. Again, many thanks!
Posted: 29 Jan 2020, 21:24
by WB8AM
Quick question. Page 136 of the instructions show that in WSJT settings the UDP server port is set to 2333. Also on the same page, the UDP_INBOUND, JT_MESSAGE connector in L4OM2 is unchecked. Is this correct?
- Picture1.png (166.04 KiB) Viewed 5309 times
Posted: 30 Jan 2020, 00:49
by NN7D
OM,
That unchecked setting was for use without JTAlert running. Sorry for the confusion. During testing we have many settings which are turned on/off as needed. Eventually I suspect we will clean up those examples. So no, that entry should not be checked and is not needed - assuming you are running JTAlert.
Doug - W7DRM
Posted: 31 Jan 2020, 08:37
by IW3GCR
Good morning,
I too have the same problem with jtalert last version.
But if I try to go into the jtalert configuration I get the error:
Fatal error- MySql Start Failure-Program will now exit.
And with the previous V4 version of log4om everything worked.
I tried again, reinstalling previous jtalert and it works, but as soon as I install the last one, here is the error.
However, I must point out that I have kept both versions of log4om ie both v1 and v2.
Thank you
Posted: 31 Jan 2020, 10:13
IW3GCR wrote: ↑31 Jan 2020, 08:37
Good morning,
Thank you
This is an issue you should address to JTAlert, it is not a Loh4OM issue, I have heard of several cases of this problem
