MYSQL deploy - MariaDB
Posted: 16 Jan 2020, 09:16
Good evening
I am attempt to deploy the sql server. The sql server currently holds my LOG4OM v1 database. I have used a different name but on the same server. It is a mariaDB as MYSQL is rare on linux.(CentOS Server)
not sure were to go. as log indicates a script error.
73's
de
Emma Cuthbert
VK1DC
Code: Select all
2020-01-16 09:08:03.7185 ERROR: [DbMysql][Deploy] : MYSQL Error while deploying database -2147467259 You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'JSON ,
`contestid` VARCHAR(50) DEFAU' at line 24
[EXCEPTION] You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'JSON ,
`contestid` VARCHAR(50) DEFAU' at line 24 MySql.Data.MySqlClient.MySqlException (0x80004005): You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'JSON ,
73's
de
Emma Cuthbert
VK1DC
