v2 and eQSL
F4IEX
v2 and eQSL
Post by F4IEX »
Evening all,
After reading the full user guide and searching here and there in the program, I cannot find any function to show or import my rx'ed eQSL's. At least, just like in the v1 with the "QSL Archive" feature.
Did I miss something ?
Thanks in advance. 73
F4IEX Eric
Re: v2 and eQSL
Utilities/QSL Manager .... Select a Service like QSL, EQSL, LotW or others and hit the Download confirmations
button .... See attached picture:
F4IEX
Re: v2 and eQSL
Post by F4IEX »
Sorry Juergen, I may not have explained correctly. If I am not wrong, what you describe allows only to display the eQSL status in green (confirmed). My question is there is a way to show ON SCREEN, in the Edit QSO window for example, the eQSL received ?
g0ggg
Re: v2 and eQSL
Post by g0ggg »
hI Eric,
I've tested the EQSL download function into redirected onedrive directory and the it looks to create correctly.
The issue is the display function in the Document Tab is not implemented yet.
Please see G4pop post in section below.
neil g0ggg
F4IEX
Re: v2 and eQSL
Post by F4IEX »
Hi Neil,
Thanks for your help. What G4POP's post do you refer to?
LA9FFA
Re: v2 and eQSL
Post by LA9FFA »
Re: v2 and eQSL
double click on a QSO and then check the "QSL info" tab.
F4IEX
Re: v2 and eQSL
Post by F4IEX »
Thanks everybody for replies. V2 is excellent so far and will be even better after updates! Great job!
F4IEX Eric
