Propagation Mode MS-how can set right RST?
I have problem now in v2 with RST for FSK441 and MSK144 modes. By editing QSO are always RST set as 599 and i have right changed it. It worked in v1 but now in v2 i can't write RST more, only select RST between 111 that 599 by FSK441. If i need set RST 26, after select 261, 262, 263 etc. It's strange and by MSK144 now in v2 is still hard I make rcvd QSL cards and i can't edit all FSK441 and FSK144 QSO's because i can't set right RST back Thansk for help
Re: Propagation Mode MS-how can set right RST?
Hello Drahomir, good question. There is a file called rst.xml in the Log4OM config directory. Click on Help --> Open config folder.
Make a backup of the rst.xml !!! Just in case you need to go back. Then you can edit the file. Look for a section called
Downside, this file probably gets overwritten on the next Log4OM update....
Roland
Code: Select all
<ModeType>DIGITAL</ModeType
Roland
Flex 6600 - Spiderbeam
