I am using the latest release of Log4OM (2.2.0.0). I have it set to automatically upload QSOs to eQSL and Clublog as they are logged (after the random delay). At the end of an operating session, using QSL Manager, I like to download new confirmations from eQSL, then upload new QSOs to LOTW, then download new confirmations from LOTW, then finally upload those new LOTW confirmations to Clublog. It's this last bit that I can't figure out how to do easily in v2.
I've been going through this procedure since I started using v1 and the whole thing takes only a couple of minutes. Having downloaded LOTW confirmations I just sort on LOTW date received, then select QSOs back to the last time I uploaded to Clublog, then move across to the Clublog tab in which the previously selected QSOs are still visible and do a Clublog upload. At no point do I have to worry about noting the callsigns of the updated QSOs, it's all done via dates.
However, I can't get this to work in v2. When I select the QSOs in the LOTW dropdown after downloading confirmations, the selection does not persist across to the Clublog dropdown. Also in the Clublog dropdown, I cannot find a way of getting the LOTW received date to display. I can see the LOTW status, but not date (it's not available as a column). Hence, other than noting all the callsigns and then searching for those manually, I can't think of a way to upload their new status to Clublog.
Really would appreciate guidance on how to do this. I have read the manual, watched the latest v2 YouTubes and done a lot of button clicking, all to no avail. Feel I must be missing something simple in this mighty piece of software.
