hello, just started with this program (i like ) and i have 2 for the to do list if is possible,
- if is possible to change the order of field in the cluster windows (i like to see the NOTE field) yes i slide to right but if is possible...
- and if also possible a configurable button to call externa program, like wsjt fldigi etc..(not in the cron)
for the rest i am young in this.. but is symple and now i try this, congrats
ciao for now, raf ik4idf
for to do list
Re: for to do list
Raf,
if you want the note field more to the left, just put the pointer of the mouse on the header 'note', and then slide it to the positon you want by holding down the left mouse key.
73, Peter, PE4A
73, Peter, PE4A
Re: for to do list
wow..grazie Peter.. when i return @home ill try immediatly... good!
Re: for to do list
Also note besides changing location you can turn the columns on and off that you want and rename them as well.
Re: for to do list
You could add the QSO record to QRZCQ.com as you would to QRZ.com
Authorization with the API Key
Regards
Regards
SGC PowerClear, EMU0202
73!
Jan SQ9JXB
73!
Jan SQ9JXB
