Manually Inputting Logs
WA2SQQ
Post by WA2SQQ »
I have quite a few contacts to manually input into V2. Did a search for "manual input" and wasn't able to find any specific tips for doing this, where such things as date / time / band and freq are manually inputted w/o any intervention from LOG4OM. Suggestions?
Re: Manually Inputting Logs
I love Log4OM but the thought of entering a bunch of files manually makes my head hurt.
I might consider entering them into an Excel file and there are Excel to ADIF converters out there that would make an ADIF file that Log4OM would import.
WA2SQQ wrote: 09 Feb 2020, 21:51 I have quite a few contacts to manually input into V2. Did a search for "manual input" and wasn't able to find any specific tips for doing this, where such things as date / time / band and freq are manually inputted w/o any intervention from LOG4OM. Suggestions?
If I were you I would wait until we can refine manual input, you can do it now but we will make it easier
WA2SQQ
Post by WA2SQQ »
I’ll take your advice Terry. Thanks
Am I correct that while can import ADIF files, at this time V2 can’t merge an ADIF into an existing file?
You can merge ADIF files into existing Log4OM log. I do it every contest.
Run N1MM for the contest and after contest I export the ADIF file and import into Log4MM
WA2SQQ wrote: 10 Feb 2020, 00:18 I’ll take your advice Terry. Thanks
Not merge as in updating existing records with records of the same QSO'S but with updated information like QSL status etc
You can add new records containg different QSO'S to and existing database
SM5DGE
Post by SM5DGE »
I used FLE "Fast Log Entry" by DF3CB. Take a look: https://df3cb.com/fle/
/SM5DGE Joe
WA2SQQ
Post by WA2SQQ »
Joe
Thank you for sharing this! Hopefully Terry can comment on my questions:
1. So, do you have to configure this program to have each data column in the same order as LOG4OM V2?
2. In the example, I see band, but not frequency. Can you add fields?
3. From doing the export of V1 to the import to V2 I learned from Terry that there are different ADIF. Have you used this with V2 yet?
4. So, once you create the ADIF file, you import it into V2?
SM5DGE
Post by SM5DGE »
WA2SQQ wrote: 12 Feb 2020, 16:07 Joe
Bob
1. No, not possible.
2. Available fields are displayed in "Options" (Alt + E).
3. Yes, import to V2 is OK. FLE is compliant with ADIF 3.0.6.
4. Yes.
