PSTRotator not hearing L4OM
n6oil
Post by n6oil »
Hey guys,
I can't seem to get my PSTRotator program to track L4OMv2. I have UDP_OUTBOUND set to the default port for PST 12040 and the it's set as active in the connections window. In PST I have L4OM set as tracking.
I must be missing something simple.
Rory-N6OIL
SQ5TDZ
Re: PSTRotator not hearing L4OM
Post by SQ5TDZ »
I have it so set up
Image Image Image
Andrew.....SQ5TDZ
n6oil
Post by n6oil »
Thanks, Andrew, I'll change that to 12040 instead of 12000. I thought the 2 were separate.
Rory
N6OIL
n6oil
Post by n6oil »
Well no luck, still won't turn the rotor.
N6OIL
PA1WBU
Post by PA1WBU »
FWIW, this is what I use:
and
Note that I did not have to change the PSTrotator config from what I used on L4OM V1. "Just worked" out of the box with L4OM V2.
Hope it is of any use to you.
73 Wilko
G3ZSS
Post by G3ZSS »
Note you are showing you are using UDP Port 12040 in Log4OM2 and 12000 in PSTRotator. They should both be the same!
73 Peter G3ZSS
