POSTING MY WAS AWARD ON LOG40M
AH6TX
Post by AH6TX » 24 Mar 2020, 20:49
I recently received my WAS award certificate from ARRL. How do I add it into LOG40M?
Howard
AH6TX
gvm920@gmail.com
818-203-5337
Re: POSTING MY WAS AWARD ON LOG40M
Post by KI5IO » 25 Mar 2020, 02:34
Howard,
Have you looked at WAS in the Award Statistics window?
Have you download (detail download) from LOTW with your validated Q's?
AH6TX
Post by AH6TX » 25 Mar 2020, 05:41
Yes. I did. I received my WAS certificate #63301. I just want to have it show up on my LOG4OM software.
Post by G4POP » 25 Mar 2020, 07:48
AH6TX wrote:
25 Mar 2020, 05:41
Where and how would you want it to 'Show up'
AH6TX
Post by AH6TX » 25 Mar 2020, 20:04
I believe I should show up under f3 so that when someone else pulls me up as a contact they can see my awards. If you have other suggestions I would like to see/hear them.
Howard
Post by G4POP » 25 Mar 2020, 20:17
AH6TX wrote:
25 Mar 2020, 20:04
Howard
Why not post it as your photo on QRZ then anyone looking you up in Log4om will see the award
AH6TX
Post by AH6TX » 26 Mar 2020, 20:27
I understand. If that be the case what is the purpose of the database field/column for?
Howard
ah6atx
Post by G4POP » 26 Mar 2020, 20:52
AH6TX wrote:
26 Mar 2020, 20:27
Howard
ah6atx
Which data base field column are you referring to?
