Hello to all,
I'm going back to my simple Custom Award to ask for help again.
My award is only for Fed.Republic Germany / FT8 / 40m QSO ( that I have selected in the first window of the Award Editor) but I have noticed that many times the "Award Statistics" takes as valid also QSO in CW or SSB mode and on other bands .
So if I use "Rescan Award References" for all my log, the QSO of all modes and bands are considered valid.
Can you tell me what mistake I made?
I thank you in advance for your reply.
CUSTOM AWARD 2^ round
Re: CUSTOM AWARD 2^ round
Vincenzo,Vincenzo wrote: ↑25 Mar 2020, 16:41 Hello to all,
You dont provide enough information about the construction of your award, in future export the award and post it in a zip file on the forum so that we can see what you have done wrong.
I suspect that you did not select an award type or search field and probably did not add a reference for FT8 to be scanned.
I have constructed what I think you are trying to achieve and its attached below, un zip the file then use the File/Import award menu at the top left corner of the awards manager to import it. Dont forget to rescan the award in the award view.
You will be able to open the award in the award manager and hopefully see what mistakes you made.
thanks for the example file you have attached so I understood the error I was making because I was using a different processing system.
I am attaching the file of my BSA custom award for FT8 in 40mt that I made and I hope that the problem I encountered is clearer.
I was forced to apply a filter to eliminate unnecessary calls because the program considered all QSOs valid both in Digital and in SSB.
Finally today I uploaded the program to ver 2.5 and all the custom awards that I had made are gone but I had a copy of them on a second folder and I was able to recover them but I don't know if this problem is normal or my mistake.
73 de Vincenzo I8BVW
- GSA for I8BVW.xml
- (1.65 KiB) Downloaded 176 times
