world map does not use locator
sp9wpn
Post by sp9wpn » 26 Mar 2020, 19:30
For stations from US, this is very visible difference between maps:
kd0zv
Re: world map does not use locator
Post by kd0zv » 26 Mar 2020, 20:01
Have you tried other callsigns?
That example you gave is jacked up for me as well. Other call signs work fine.
Log4OM Version 2.4.0
Windows 10/64
Flex 6600 via OmniRig (testing HamLib)
CW Skimmer localhost
Post by KI5IO » 26 Mar 2020, 20:11
AL2F is in the midst of moving back to Alaska. If you look at his QRZ page you will note he has posted that he moved back to AK on 03/23/2020.
I'm sure he has not fully updated all his data sources, nor have those updates populated throughout the system.
I would expect some differences insituations as this.
I'm amazed that the OM has put that current of an update on his QRZ page. Very few OMs are that detailed to do so.
sp9wpn
Post by sp9wpn » 27 Mar 2020, 14:46
Now I've noticed "CLUBLOG CALL EXC". Log4OM definitely gets the correct locator (see locator field and right map). It's just left map which is not updated when the exceptional locator is downloaded. So the correct data is here in Log4OM, it's about the presentation.
W7DRM
Post by W7DRM » 31 Mar 2020, 21:41
Works fine for me. Of course, all based on accurate Grid data.
Doug
W7DRM
