Award Statistics, wrong totals ?
hb9cat
Post by hb9cat »
Award Statistics > DXCC > Statistics Tab
shows nicely a table the amount of worked/confirmed etc. qsos per band.
The issue is that the rightmost column showing Totals per confirmation level is not calculating the totals properly, example:
WORKED 80 99 187 135 233 121 145 48 83 55 290
CONFIRMED 68 75 161 118 186 84 112 25 51 40 262
Righmost values should be 1186 (not 290) and 920 (not 262)
Or am I interpreting this wrongly ?
Marco HB9CAT
Re: Award Statistics, wrong totals ?
No Right most column is the total countries worked it is not a total of all of the others
Because you could have worked a country several times on different bands like VK on 20, 15 & 10 but you only worked VK is one DXCC entity
The other way would just be a total number of QSO's not a DXCC score, DXCC is all about working DXCC entities the maximum possible is about 340
hb9cat
Post by hb9cat »
Ok Terry,
you're obviously right, I did not formulate my question correctly: I am looking for the DX Challenge statistics, so the sum of all the band countries.
I did:
- View > Award statistics
- Award: DXCC
- Predefined config: Challenge
- then I looked at the statistics tab
What the right way to see the DXCC Challenge totals ?
Marco
Ah!
There is a problem with Challenge and WPX awards which we have yet to resolve!
