Error submodes
Re: Error submodes
Hi Michel,
if you open the modelist.csv in the Log4OM configuration folder you will see that all submodes
are in the list. Including THOR, TOR, DOMINO and CONTESTIA. The only error i can find is that
CONTESTIA has a missing A at the end. You can change this with an editor like Notepad ++.
V2 is using strictly ADIF 3 and the submodes are a must have. I don´t know Fldigi is using the
ADIF3 standard but if not the mistake should be on the Fldigi site.
If you don´t know where your config folder is open Log4OM and hit the HELP TAB, in pulldown
use "Open configuration folder" ....
Re: Error submodes
Hello Michele,
sorry about my mistake with CONTESTI vs CONTESTIA. Don´t know where the problem is so
i don´t use all these modes and i don´t have software installed for this. Means i can´t test
it.
Maybe another User/Teammeber can check..... Will inform the Team.
