Hi all,
This was never a problem but recently if I click a callsign in wsjtx it displays in Log4om with all the info. Just like it always did. Then all of a sudden it just stops and the only way I seem to get it working is to close wsjtx and Log4om and restart them. Anyone had similar happen?
73 Brent G5TV.
Wsjtx randomly stops communication with Log4om v2
Re: Wsjtx randomly stops communication with Log4om v2
Nobody has reported this before. Did you have Omnirig, WSJT-X and Log4OM running as administrator ?
My 'input' is for Log4OM v2, as in the thread title, even though we're in the V1 forum.
I see the same thing here. Just a guess as always: Looks like if JTAlert loses the connection to the port, for whatever reason, Log4OM v2 takes control of it and won't share. The 'solution' in my case has been to close both JTAlert and Log4OM v2, and then re-open JTAlert first, followed by Log4OM v2. The sequence is important.
I did not have JTAlert running as admin, I will try that now.
What versions of Log4om, wsjt and JTalert are you using, actual release numbers please not just "the latest"!
Not sure if the question was directed at me, but here it goes:G4POP wrote: 30 Jun 2020, 16:40 What versions of Log4om, wsjt and JTalert are you using, actual release numbers please not just "the latest"!
Log4OM 2.7.0.0
JTDX v2.1.0-rc151
JTAlert 2.16.8
The latest. :^)
73 de Vince, VA3VF
We are in v2.va3vf wrote: 30 Jun 2020, 16:06 My 'input' is for Log4OM v2, as in the thread title, even though we're in the V1 forum.
Cheers all sorted I reinstalled wsjtx and forgot to run as administrator.DF5WW wrote: 30 Jun 2020, 14:42 Nobody has reported this before. Did you have Omnirig, WSJT-X and Log4OM running as administrator ?
Regards Brent G5TV
Thank´s to reporting this.
Thank you for letting me know. It was showing in the V1 User support when I replied. In fact, I still see v2 topics in there.
I'll re-install the browser and run it as admin.
Thanks again.
73 de Vince, VA3VF
There is a flaw that may occasionally lock down the user interface in V2 since 2.7, or lock only the main grid.
We fixed the second one while we fixed almost 99% of occurrences of lock for the whole program.
We will release soon
