I have some problem in getting connection acive with FLDIGI ; frequency is lost and logginf in missing
I have somme error in activity log but I am not able to expoe them and send them to you for addressing possbile problem.
the sequence you suggest in application opening is not working in stable way
some more infor at user level could help
FLDIGI integration stability
73 de Don IK2EGL
Re: FLDIGI integration stability
You could email Daniele or me the program log and then we might be able to identify your issue
I use FLdigi with Log4OM on a daily basis without issue so your problem has to be local to your setup
fully understood and Solved
in the FLDIIGI Setting window the FLDIGI ADDRESS MUST BE http://localhost
DO NOT USE the IP ADDRESS 127.0.0.1 (, otherwise the log will say "ERROR .... INVALID URI"
Daniele took a note and will standardize the localhost IP address in all configuration windows
73 de Don IK2EGL
