Program crashed
F4IEX
Program crashed
Post by F4IEX »
Hi all,
Today, when started Log4OM, it appeared that the program had a crash and the log is empty, i.e. no config file and 0 contact in log. Followed the instructions as mentioned in the manual to recover everything but, in spite of several tries, my previous configuration and log do not run. Where is the problem?
Thanks,
F4IEX Eric
Re: Program crashed
Sounds like you copied the wrong config file, the one to use is in the USER folder
F4IEX
Re: Program crashed
Post by F4IEX »
Well, don't know why but it suddendly worked... after 5 tries...
F4IEX
Re: Program crashed
Post by F4IEX »
And once again the same problem...
Followed exactly what is told in the manual but nothing when launching Log4OM.... 4 tries so far with no luck... What am I doing wrong ?
Re: Program crashed
Load an early config file not the latest ones
F4IEX
Re: Program crashed
Post by F4IEX »
Thanks Terry it worked ! Loaded an old config file from early April instead of the latest. Thanks for help ! 73
