Hamlib Loses Settings After Shutdown
K2MO
Post by K2MO »
All:
I've noticed that Hamlib does not retain my settings when restarting Log4OM2 v2.16. The rig type becomes blank and the comport changes after shutting down and restarting the program. The previous version seemed to work fine with my Elecraft K3S and Windows 10/64 OS.
I've tried saving the configuration after setting things up but that doesn't seem to work.
Any suggestions?
Tony
Re: Hamlib Loses Settings After Shutdown
Yes known issue will be fixed when Lele returns from holiday
K2MO
Post by K2MO »
Thanks Terry
Tony -K2MO
w7nee
Post by w7nee »
I am using a Flex 6600 with Log4OM and have always used OmniRig for Cat communications. With the recommendations from Terry Genes I am now using Hamlib and SliceMaster for my rig Control. However I am experiencing this same issue with Version 2.23.0.0. I have been searching for a fix, but not finding any information with a fix for this. Hamlib works great, but loses all it settings after shutting down the application. Any suggestions? Thanks in advance!
Log4OM 2.23.0.0
Windows 10
Flex 6600 V2.7.6
SliceMaster V0.01.8a
Jeff
W7NEE
See my post of 6th August - Were working on it!
w7nee
Post by w7nee »
Thanks Terry!!
w7nee
Post by w7nee »
Hi all, I am still experiencing this problem with the loss of settings. In this thread G4POP stated they were working on the known issue. Is there something that I need to do to remedy this issue? Running v2.23.0.0
Jeff
W7NEE
You need to update to latest Beta release
w7nee
Post by w7nee »
Would that be 2.26.0.0?
w7nee wrote: 04 Mar 2023, 20:43 Would that be 2.26.0.0?
No 2.26.0.3 here https://www.log4om.com/l4ong/release/be ... 3_beta.zip
