Cluster - Filter FT8 Spots
HB9VQQ
Post by HB9VQQ »
Would it make sense to filter Cluster Spots for the known FT(x) frequency segments on each Band when "Filters - Exclude FT(x)" is selected?
Roland
Flex 6600 - Spiderbeam
Re: Cluster - Filter FT8 Spots
We already do that
HB9VQQ
Post by HB9VQQ »
Am I missing something? FT(x) Spots still coming through, see screenshot.
HB9VQQ wrote: 22 May 2022, 12:02 Am I missing something? FT(x) Spots still coming through, see screenshot.
I cant see the frequency because the screen shot is to small but I am willing to bet its outside the special FT8 frequencies below
<SpecialFrequencies>
<string>1840000|FT8</string>
<string>3573000|FT8</string>
<string>5357000|FT8</string>
<string>7074000|FT8</string>
<string>10136000|FT8</string>
<string>14074000|FT8</string>
<string>18100000|FT8</string>
<string>21074000|FT8</string>
<string>24915000|FT8</string>
<string>28074000|FT8</string>
<string>50313000|FT8</string>
<string>3575000|FT4</string>
<string>7047500|FT4</string>
<string>10140000|FT4</string>
<string>14080000|FT4</string>
<string>18104000|FT4</string>
<string>21140000|FT4</string>
<string>24919000|FT4</string>
<string>28180000|FT4</string>
<string>50318000|FT4</string>
</SpecialFrequencies>
HB9VQQ
Post by HB9VQQ »
It is 28076 well within the 2kHz of the FT8 segment. I see you are not looking at a range, only at a single fixed frequency. If the reported Spot is not exactly on that frequency, but still within the FT8(x) segment it's a miss.
I beleive they are the frequencies used in the WSJT list
HB9VQQ
Post by HB9VQQ »
You can check PSKReporter for the reported frequencies, most are outside of the "nominal" FT(x) frequencies. I think it would work better if you look at a range instead of a single frequency.
Roland
I'll check. We can use actual bandplan ranges or add a +- tolerance.
I'll check
Inviato dal mio SM-A715F utilizzando Tapatalk
HB9VQQ
Post by HB9VQQ »
Thank you Lele
HB9VQQ
Post by HB9VQQ »
Any progress on this?
