Hello All,
Hopefully this is an easy one. My Cluster(f8) stays connected fine but it does not refresh the spots. aka I connect and it populates with current spots but then stops. The older spots remain on the screen hours after posting. I must disconnect and reconnect to get new.. I must have a setting wrong...?
Thank you, John K5AV in TX
Cluster spots will not update
Re: Cluster spots will not update
Firstly as always what is the Log4OM version number? See help/About
Check what filters are set
Watch the raw data being received in the Telnet window
Hello Terry and HNY,
Apologies for my late response.
LOG4OM 2 V.2.11.0.0
I have all band filters set but I do change them.
In Cluster management>management raw data scrolls constantly via N8DXE. But still in Cluster(F8), it holds on to the spots when I first log in and never changes... Im sure I have a setting wrong somewhere.... Thank you, Chris
LOG4OM 2 V.2.11.0.0
Chris,
Current version of Log4om is V 2.25
Update to the current version and see if your issue goes away.
I have Log4OM 2 – 2.32.1.0 and I've the same problem
Piotr
Piotr
