Just downloaded 2.25.0..
In QSO Manager when using the filter option.
Noticed when I went to do a filtered select that no dropdown appears in References or My References...
I normally use this for a selective SOTA upload to ADIF..
Working in previous versions...
Keith
EI5KO
Filters in QSO Manager
Re: Filters in QSO Manager
Anyone else have this issue?
Settings/update resources/Log4OM Rewards
Then restart Log4OM
Then restart Log4OM
Tried as you suggested but still nothing..
Tells me
Awards Updated
Awards Database has been updated
But still asking to Load References after a restart of Log4OM..
Keith
Tells me
Awards Updated
Keith
Same....Field not being populated...
It was OK in previous versions....
Issue has only arisen since 2.25 and I updated to 2.26 just in case..
Regards
Keith
Regards
Keith
Stumbled upon this thread as I am having the same issue. In Ver2.25 and later no references are loaded in dropdown for the filters. Get an error if I click "load references". Went back to Ver2.24 and options under dropdown for references/myreferences are available and "load references" works as expected.
The "Settings/update resources/Log4OM Rewards" didn't help.
Let me know it there is something else to try.
Thanks!
Jim/K7MK
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at L4ONG.Controls.References.UCSearchReferences.dje_zH4MFWSSK_ejd()
at L4ONG.Controls.References.UCSearchReferences.dje_z98BYTTVUZNVGYDQJ3EC53G68T62A_ejd.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at L4ONG.Controls.References.UCSearchReferences.dje_zAHU8MQEBZVJADVNLWM9T9QSVNAKPH8QCMW_ejd.MoveNext()
at System.Runtime.CompilerServices.AsyncMethodBuilderCore.<>c.<ThrowAsync>b__6_0(Object state)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.9139.0 built by: NET481REL1LAST_B
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
L4ONG
Assembly Version: 2.27.1.0
Win32 Version: 2.27.1.0
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/L4ONG.exe
System.Windows.Forms
Win32 Version: 4.8.9075.0 built by: NET481REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
L4ONG.Framework
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/L4ONG.Framework.DLL
L4ONG.Common
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/L4ONG.Common.DLL
L4ONG.BE
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/L4ONG.BE.DLL
L4ONG.Storage
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/L4ONG.Storage.DLL
L4ONG.Logger
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/L4ONG.Logger.DLL
System.Drawing
Win32 Version: 4.8.9032.0 built by: NET481REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
Microsoft.Extensions.Caching.Memory
Assembly Version: 7.0.0.0
Win32 Version: 7.0.22.51805
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/Microsoft.Extensions.Caching.Memory.DLL
Microsoft.Extensions.Options
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/Microsoft.Extensions.Options.DLL
Microsoft.Extensions.Caching.Abstractions
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/Microsoft.Extensions.Caching.Abstractions.DLL
Microsoft.Extensions.Logging.Abstractions
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/Microsoft.Extensions.Logging.Abstractions.DLL
Microsoft.Extensions.Primitives
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/Microsoft.Extensions.Primitives.DLL
INIFileParser
Assembly Version: 2.5.2.0
Win32 Version: 2.5.2
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/INIFileParser.DLL
L4ONG.BL
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/L4ONG.BL.DLL
L4ONG.Controls
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/L4ONG.Controls.DLL
NLog
Assembly Version: 5.0.0.0
Win32 Version: 5.1.1.1522
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/NLog.DLL
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Newtonsoft.Json
Assembly Version: 13.0.0.0
Win32 Version: 13.0.2.27524
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/Newtonsoft.Json.DLL
System.Numerics
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
System.Runtime.Serialization
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
System.Data
Win32 Version: 4.8.9110.0 built by: NET481REL1LAST_B
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
L4ONG.VOACAP
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/L4ONG.VOACAP.DLL
L4ONG.CAT
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/L4ONG.CAT.DLL
Accessibility
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
L4ONG.Cluster
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/L4ONG.Cluster.DLL
GMap.NET.WindowsForms
Assembly Version: 1.7.5.0
Win32 Version: 1.7.5
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/GMap.NET.WindowsForms.DLL
GMap.NET.Core
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/GMap.NET.Core.DLL
System.Data.SQLite
Assembly Version: 1.0.117.0
Win32 Version: 1.0.117.0
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/System.Data.SQLite.DLL
System.Transactions
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
L4ONG.BL.CAT
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/L4ONG.BL.CAT.DLL
System.Windows.Forms.DataVisualization
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.DataVisualization/v4.0_4.0.0.0__31bf3856ad364e35/System.Windows.Forms.DataVisualization.dll
L4ONG.BL.INIT
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/L4ONG.BL.INIT.DLL
L4ONG.DAL.AWARDS
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/L4ONG.DAL.AWARDS.DLL
System.Web
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
Microsoft.GeneratedCode
Assembly Version: 1.0.0.0
System.EnterpriseServices
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
L4ONG.DAL
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/L4ONG.DAL.DLL
L4ONG.BL.KEYERENGINE
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/L4ONG.BL.KEYERENGINE.DLL
L4ONG.BL.CLUSTER
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/L4ONG.BL.CLUSTER.DLL
L4ONG.BL.VOACAP
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/L4ONG.BL.VOACAP.DLL
L4ONG.WEATHER
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/L4ONG.WEATHER.DLL
L4ONG.TALK
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/L4ONG.TALK.DLL
L4ONG.BL.FLDIGI
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/L4ONG.BL.FLDIGI.DLL
L4ONG.BL.DATASEARCH
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/L4ONG.BL.DATASEARCH.DLL
L4ONG.INTERFACES
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/L4ONG.INTERFACES.DLL
L4ONG.DAL.SQLITE
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/L4ONG.DAL.SQLITE.DLL
L4ONG.DAL.MYSQL
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/L4ONG.DAL.MYSQL.DLL
L4ONG.BL.WORKEDBEFORE
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/L4ONG.BL.WORKEDBEFORE.DLL
L4ONG.TCPServer
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/L4ONG.TCPServer.DLL
WebSocket4Net
Assembly Version: 0.15.2.11
Win32 Version: 0.15.2.11
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/WebSocket4Net.DLL
SuperSocket.ClientEngine
Assembly Version: 0.10.0.0
Win32 Version: 0.10.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/SuperSocket.ClientEngine.DLL
L4ONG.BL.AWARDS
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/L4ONG.BL.AWARDS.DLL
L4ONG.Webpage
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/L4ONG.Webpage.DLL
L4ONG.DAL.EXTDATA
CodeBase: file:///C:/Program%20Files%20(x86)/IW3HMH/Log4OM%20NextGen/L4ONG.DAL.EXTDATA.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Thanks!
Jim/K7MK
mscorlib
L4ONG
System
L4ONG.Framework
L4ONG.Common
L4ONG.BE
L4ONG.Storage
L4ONG.Logger
System.Drawing
System.Core
INIFileParser
L4ONG.BL
L4ONG.Controls
NLog
System.Xml
Newtonsoft.Json
System.Numerics
System.Data
L4ONG.VOACAP
L4ONG.CAT
Accessibility
L4ONG.Cluster
GMap.NET.Core
System.Data.SQLite
System.Transactions
L4ONG.BL.CAT
L4ONG.BL.INIT
L4ONG.DAL.AWARDS
System.Web
L4ONG.DAL
L4ONG.BL.CLUSTER
L4ONG.BL.VOACAP
L4ONG.WEATHER
L4ONG.TALK
L4ONG.BL.FLDIGI
L4ONG.BL.DATASEARCH
L4ONG.INTERFACES
L4ONG.DAL.SQLITE
L4ONG.DAL.MYSQL
L4ONG.TCPServer
WebSocket4Net
L4ONG.BL.AWARDS
L4ONG.Webpage
L4ONG.DAL.EXTDATA
enabled.
For example:
<configuration>
</configuration>
- Screenshot 2023-05-17 224115.jpg (83.38 KiB) Viewed 1329 times
The "Award" presence in the References / My References dropdown in the Filter panel has been repaired.k7mk wrote: ↑18 May 2023, 04:43 Stumbled upon this thread as I am having the same issue. In Ver2.25 and later no references are loaded in dropdown for the filters. Get an error if I click "load references". Went back to Ver2.24 and options under dropdown for references/myreferences are available and "load references" works as expected.
Thanks!
Jim/K7MK
V 2.27.1.10 https://www.log4om.com/download/
Nolan,
Thanks for the update. I can confirm that the filters are indeed working in V 2.27.1.10. Thanks for the fix!
Best Regards.
Jim/K7MK
Best Regards.
Jim/K7MK
