HI Guys, as a very new user my apology if this was discussed before.
First of all thank you very much for this great software. I just learning to use it and have some questions. I'd search the forum for the answer first instead of boring you. But I've got stuck at the 1st step. For example: I saw some annoying wrong cluster spots such as WTRC suffix instead of WRTC. This could be confusing so I'd rather remove them from the spots list (like right-click on spot and click on "remove spot" in N1MM+). Okay, let's search for the forum.
I've been trying search for "remove cluster spots" then +cluster +spot and some other formats but I've got always the search is too common too short, and did not get any useful answer.
I need your help what do I wrong?
TNX in advance, 73! Viktor HA5LV
