Cat Control not working with Yaesu FT767GX
Posted: 06 Feb 2023, 16:13
I am trying to connect my Yaesu FT767GX to Log4OM2 in order to access the frequencency etc but I have not managed to get communications working and wondered if anyone can offer any advice.
Here is what I have done so far.
I watched a series of youtube videos by CT2JKO where he serviced a FT767GX and finished off testing the CAT interface with DXLab Suite Commander so I decided this was a good place to start.
I purchased a FT-Cable-3-USB from XGGcomms and connected it to my computer running Windows 10
I downloaded and installed DXLab Suite Commander and configured the comms as follows.
COM5 (the port used by the FT-Cable -3 indicated in device manager)
Baud 4800, No Parity, 2 stop bits, DTR off, RTS TX, Command interval 200ms, scan dwell 1
This configuration works fine and I can control the frequency / mode etc from commander and it will read back the values if I change the controls or frequency on the rig directly.
During operation the CAT light on the rig flashes at a rate of about 750ms
Having confirmed that the cable and comms work I proceeded to download and install LOG4OM 2 ver 2.26.0.0
I noted that OmniRig does not support the FT767GX so selected to use Hamlib.
Settings used were :-
Settings TAB
Hamlib, CAT delay 250ms
Hamlib TAB
Rig Model Yaesu FT767GX Stable, Port COM5, Baud 4800, 2 Stop bits, DCD None, Polling delay 2000
This results in a Generated paramater string :-
--model=1009 --rig-file=COM5 --serial-speed=4800 --port=4532 --set-conf=stop_bits=2 -Z
I then selected Connect / CAT/ Start CAT and the CAT light on the rig flashes twice and then goes off. During this time the CAT indicator in LOG4OM2 stays solid green and then turns off.
No frequency or other data is displayed just OFFLinE
If I repeat the above i.e. Connect / CAT/ Start CAT. I get the same results.
Next step was to install FLDigi to see if RIGCat would communicate but then discovered that RIGCat does not support the FT767GX. At this point I noted that Fldigi also supported HAMLib so I decided to look at the setup there.
I noticed that in FLDigi different parameters are exposed to the user so I proceeded to setup Hamlib and test it.
Settings used were:-
Rig Yaesu FT767GX Stable, Port COM5, Baud 4800, 2 Stop bits, Polling interval 250ms, Timeout 3000ms, write delay 50ms, Post write delay 5 ms
Suprisingly this setup worked and the frequency and mode data were displayed and were controllable, but the response was slower than commander.
Software versions were Fldigi 4.1.23, Hamlib 4.1
After doing a bit of research on rigctl I next modified the Log4OM2 Hamlib Used Parameter string to incorporate some of the additional parameters used in the hamlib 4.1 version used in FLDigi as below.
model=1009 --rig-file=COM5 --serial-speed=4800 --port=4532 --set-conf=stop_bits=2 --set-conf=timeout=3000 --set-conf=write_delay=50 --set-conf=post_write_delay=5 -Z
I tried this with and without the –port=4532 parameter used in the Generated paramater string as I could not find any details on what this parameter does.
Either way the results were the same as with the original generated parameter string, the CAT light on the rig flashes twice and then goes off with just OFFLinE displayed.
Between tests of different software I rebooted the PC to ensure no stray bits of software were running and grabbing the serial port.
I have now run out of ideas and I am hoping someone might be able to suggest why the hamlib 4.1 version communicates with the rig but the version used in Log4OM2 does not. I cannot find any information on the hamlib version incorporated in Log4OM2.
Sorry for the long post but I wanted to provide as much information as possible.
Phill, G6TSJ
Settings TAB
Hamlib TAB
Phill, G6TSJ
