EQSL
es2hv
EQSL
Post by es2hv »
versio 2.26.07 not uploade Eqsl QSO
Re: EQSL
es2hv wrote: 07 Mar 2023, 12:42 versio 2.26.07 not uploade Eqsl QSO
Viktor,
Are these QSOs you have made via an FTxx mode? IE: WSJTx, JTDX, JTAlert, etc., etc. ??
Did you closely read the Release Notes for the V2.26.0.7 ?
Assuming your have had UDP connections set up the Release Notes advise that you have to remove your existing connections and re-establish them.
One of the options that is part of the new UDP setup is a tic box if you want to upload the QSO to external sources.
Pls review that and adjust and you should be FB.
F6FLU
Re: EQSL
Post by F6FLU »
Hello Nolan
can we download the release note of a Beta version without downloading this version ?
Just want to know what changes have been made ?
Thanks & 73
Dan - F6FLU
https://F6FLU.org
Re: EQSL
F6FLU wrote: 07 Mar 2023, 14:02 Hello Nolan
Thanks & 73
Dan,
Check your e-mail. PDF sent over.
es2hv
Re: EQSL
Post by es2hv »
I did KI5IO according to your advice but to no avail, I went back to version 2.26.03
