Automatic upload to QRZ / Eqsl / Clublog
K4TOR
Post by K4TOR »
Did something change in 2.27.1.0 regarding automatic uploads? Looks like I have to force uploads to QRZ / Eqsl / Clublog. Previous version normally uploaded within 4-5 minutes.
Tor - K4TOR
73 de Tor - K4TOR
Pee Dee of SC
Re: Automatic upload to QRZ / Eqsl / Clublog
Tor,
If the inputs are via UDP Inbound Connections ... have you deleted and rebuilt them as noted?
https://forum.log4om.com/viewtopic.php?p=43147#p43147
K4TOR
Post by K4TOR »
KI5IO wrote: 22 Mar 2023, 15:17 Tor,
Nolan,
I just realized this after I posted the message. Rebuilt and tested. Works fine.
73 de Tor - K4TOR
Pee Dee of SC
ei3grb
Post by ei3grb »
had all up loads (eQSL, HRD, Clublog, ) working fine and in the middle of a session on ft8 auto uploads just stopped. LOTW works fine on shut down as does manual upload.
I thought at first it was an internet issue, but no. Closing Log4OM , and restarting pc make no difference,
Deleted and set up UDP and checked all other settings
Not a huge issue but damn annoying
Sounds like rf in shack
ei3grb
Post by ei3grb »
100% sure definitely not rf
And you are on 2.27.1 ?
I have had no issues with uploads after new version installed, deleting connection and re-adding them.
K2IBM
Post by K2IBM »
Just one typo entering a port number can break the whole system. And unless you wrote down the old information it takes a while to get it working again. Don't ask how I know!
Glad you are working.
But really you just need to match the port with whatever program you are connecting with. So go into that program and see what it set at. As long as the match and don't conflict it should work :)
Let us know if you need anything else.
